Radio Question
Radio Question
Im getting into the slope flying area of this hobby and i need to know what radio setup i should use i want to go with hitec but im not sure what combination would be good to use but i only need a 2 channel remote so if someone has any answer please tell me.
thanks in advance
thanks in advance
RE: Radio Question
http://www3.towerhobbies.com/cgi-bin...I=LXCXM7**&P=7
This is the least expensive way with a simple small rudder/elevator glider but as you progress you will soon be wanting more channels and a 2.4 system so sometimes it better to invest in a more capable setups of which the are very nice ones between 150 to 200 dollars.
RE: Radio Question
Personally, I would by-pass any radio that is not 2.4Ghz. However, if you want to get into the hobby dirt cheap, go to Ebay or here at RCUniverse and buy a used 72 Mhz system. They are selling for dirt cheap, as 2.4 stuff is taking over.
