bluebird servos
FL
bluebird servos
Has anybody tried these servos? If you have what is your opinion on them?
By the way the price is only $17.85 each
MIke
BMS-620DMG+HS High Torque Digital Servo (Metal Gear)10.6kg / .13sec / 52g
Double ball bearing (Si-oil)
CE Certified Strong 3 Pole Motor
Heavy duty sealed water proof case
Alloy heatsink
Digital signal design with 100% fitting square PWS
Automatic measures central ms
ALU 6061 alloy and C95 gear material
Digital IC (SOP package with 12bits transfer data)
MOS-FET driver (spirited driver able to push over 7A power)
Weight: 52g / 1.84oz
Dimensions: 40.5 x 20 x 42mm / 1.60" x 0.78" x 1.62"
[b]Torque At 6.0V: 10.6kg/cm , 190 oz/in
Speed At 6.0V: 0.13 sec / 60° at no load
Operating voltage: 4.8 - 6.0V
MIke
Alloy heatsink
