saito 72 4c open or closed
That will depend on which way the carb is installed and the arm is oriented. It's best to have the cowl off so you can see everything when setting up. If it is still not visible, try a little dental mirror or something.
Rotate the throttle arm and you'll notice it moves in and out .Farthest out ,is wide open. closes in is closed. This way you dont have to look down the carb
found a saito expert, forward opens and back to close, flying monday heck or high water , where i mess up with this feasco is i had two sig programs on the futaba 10 c radio all worked but you guessed it the carb rotation. removed the second program and good to go thanks to alllllllllllllllllll frank
My Feedback: (-1)
ORIGINAL: Insanemoondoggie
Rotate the throttle arm and you'll notice it moves in and out . Farthest out ,is wide open. closes in is closed. This way you dont have to look down the carb
