You Can Do Plane?
1 Post
RE: You Can Do Plane?
There are several threads discussing this model in its different sizes.
Good lightweight aerobatic model with 3 D potential but if you are looking for a pure 3 D machine go for a profile.
MI
Great plane made by Great Planes. Very light, with lots of wing and control surface area. It will do just about anything you want it to do and it will float like a feather on landings. In fact I had some guys at the field tell me to be carefull, because getting used to the gentle slow landings can screw you up when flying a different model that needs more landing speed. It is not built for speed and the manual will tell you this. It's meant for slower aerobatic manuvers. If you put it into a steep dive with alot of speed your going to blow the wings off.
