Three-blade props
UT
Three-blade props
Where can I find a selection of three-blade props around 15 or 16 inch diameter with 6 to 7 degrees of pitch. also spinners that will work with them. Can't seem to find much about them on the net. Trying to make a PC-6 Turbo porter look a little better. Thanks guys, MM
Banned
RE: Three-blade props
Go to www.towerhobbies.com and type in Master Airscrew. They have the props you need. I have a 14x7 on my Seagull .91 Extra 260 and my O.S .91FX Ringed loves it! I like to buy Tru-Turn Nose cones, they all fit. All you need to do is order a adaptor that's seperate from thew nose cone, that fits your engine size so you can use a Tru-Turn.
Pete
Pete
My Feedback: (-1)
ORIGINAL: rc-sport
I have great luck with Graupner props, scale look and they perform well. I also order my spinners from Dave Brown, they cut them to your need
My Feedback: (12)
IL
ORIGINAL: Gray Beard
I also like the Graupners, does DB charge extra for the cutting??? At one point TruTurn was doing it for free but I guess it was only for a short time?
ORIGINAL: rc-sport
My Feedback: (90)
ORIGINAL: MormonMike
Any good websites for Graupner ? Tower does not seem to have the bigger three blades I need. Dave Brown will work for spinners. MM
Graupner is available from http://www.hobby-lobby.com As with most brands, selection is limited 14x7, 15x8, 16x8
Zinger http://www.zingerpropeller.com/3_bladed_Propeller.htm has a broad selection of sizes. They are pretty proud $$$$ of them.
