Reload this Page >
Who produced this plane?
Old 03-09-2010, 10:19 PM
calmat
My Feedback: (70)
Default Who produced this plane?
I bought this plane recently and have no history of it. I have heard of a Kondor Extra300L produced a few years ago. Could this be it? It came with enough dust to indicate it has been around a while. Also came with a Royal 46. Help-Help-help Lou
ID:	1395047   Click image for larger version
Old 03-09-2010, 11:12 PM
JollyPopper
JollyPopper's Avatar
Default RE: Who produced this plane?
I believe it's a Balsa USA kit. Is the cowl several balsa blocks sanded to shape? And how does the wing and landing gear attach to the fuse? I have one that I built from an unstarted kit and it looks the same except for the cowl, which I shaped a bit differently from yours.
Old 03-09-2010, 11:28 PM
JollyPopper
Correction. It's a House of Balsa Extra 300L. I just looked at their website and it is still offered at $175.00.
Old 03-10-2010, 10:52 AM
calmat
My Feedback: (70)
Hi Thanks for the info. It looks like it is the HOB kit. This one has a fiberglass cowl and wheel pants. I wonder about the landing gear attachment. Looks a little weak. This kit must have been in production for some time now. Old Royal 46 engine looks new. Have not run yet. Lou
ID:	1395266   Click image for larger version
ID:	1395267   Click image for larger version
Old 03-10-2010, 11:57 AM
Gray Beard
My Feedback: (-1)
The engine really does look like new. I haven't seen one in use in years. The plane looks like it would be a kick to fly too.
Old 03-10-2010, 08:13 PM
calmat
My Feedback: (70)
Getting ready to do some flight testing soon. Removed the wheel pants and cowl for test flights. I presumed the cowl and pants were plastic because of fine finish but discovered they are balsa. Wheel pants are lots of thin layers glued together. Cowl is sheet and blocks finished to shape. Great workmanship. Hope it flies as good as it looks. Lou
Old 03-11-2010, 02:26 PM
JollyPopper
You are correct. I had forgotten about the wheel pants being a bunch of laminated balsa. Nice kit.
Old 03-11-2010, 02:54 PM
JollyPopper
A couple pics of what I did with mine. I usually try to make the finished kit look like the picture on the box unless I really don't like it.
ID:	1395949   Click image for larger version
Old 03-14-2010, 12:41 PM
calmat
My Feedback: (70)
Hi Was wondering what the balance point for the Extra would be for decent flights. Measured at the leading edge at body, about how far back from leading edge. Have no plans or book on this kit so want to start out conservative. Thanks Lou
Old 03-14-2010, 06:12 PM
JollyPopper
The plans show it to be 3 1/8 inches behind the leading edge. That puts it just in front of the main spar. You will have to experiment from there for your particular plane.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
