Hangar 9 Double vision charger
FL
Hello,
I just got this field charger and I am wondering if there is a way to convert it to be used from a wall outlet. I am guessing it will require some sort of 12v power supply, but where would one go to find something like that which hooks up via alligator clips?
My Feedback: (-1)
Radio Shack had a 12 volt converter, been some years sense I bought one but I used to run old car radios in my garage and used one. As to the clips you will have to make up your own clip to plug extension, as I recall the converter has the plugs for a normal 110V wall plug.
MI
Most bench type power supplys use a binding post type of output. You can attach a battery clip to that. I have put banana plugs on my field charger so that I can plug it into the starter output on a power panel, I also connect it to a power supply that way as well.
here are a couple of options:
http://www3.towerhobbies.com/cgi-bin...?&I=LXL356&P=7
http://www3.towerhobbies.com/cgi-bin...&I=LXWGU7&P=ML
