Do I need a regulator
Hi all
I have a futaba R 138 DP receiver, PCM1024, with Hitec HS645, also futaba S 3010, and a 3004 servos. I went to use a 2 cell 7.4 volts, 1800 mA
battery. Will it work?? Or will Ihave to have a regulator? Thanks for the help.
CA
RE: Do I need a regulator
Dan,
Keep in mind the higher the voltage the higher the current drain and the less flying time available.
Some regulators are adjustable and others can be bought for specific voltages, 6.0, 5.5, 5.0.
What is your reason for the new batteries?
If it is to get more torque and faster responses use the higher voltage.
If you are just switching to new technology use the lower voltages and fly longer.
If you are switching to LiPo it is NOT recommended you charge in the plane.
They have been know to catch fire. Odds are slim - Cost is high.
Good Luck,
KW_Counter
Good Luck,
KW_Counter
I cannot speak for other brands but I run all JR digital servos, and JR powersafe RX, with that combo I run 7.4 V lipos direct, no regs. I have been doing this for around 2.5 years now with 0 issues. Just saying...
Bob
Bob
CA
Sensei,
Are these items designed for the higher voltages?
Some manufacturers are expanding their product line for this purpose.
KW_Counter
KW_Counter
ORIGINAL: KW_Counter
Sensei,
KW_Counter
Sensei,
KW_Counter
Bob
Yes you do! only modern material can stand 7,4v. The most of the material works fine with 4,8 or 6 v. if you aren't sure it cans stand 7,4 volts, you must use an regulator.
