Solartex
My Feedback: (17)
Solartex
I started covering a plane today using white Solartex, because I didn't want to paint the plane. After covering one piece, the balsa isn't completely hidden, ie the white Solartex has some transparency. Would painting the airframe with white paint before covering work to hide the balsa? Would latex work, solvent based paints smell to much?
My Feedback: (14)
IN
RE: Solartex
If you are planning to paint the structure, then iron the Solartex over that, you might want to try a test strip. I know that when i have tried patching painted Solartex, the iron melts the paint and results in a mess. I have never had success ironing over anything painted.
My Feedback: (108)
RE: Solartex
I am thinking that if you need to paint, you would want to paint the Solartex and not the plane. When applying the covering over the paint, I would think you could have all sorts of problems trying to iron on the covering over paint. Solartex is fuel proof and the reason that it needs to be painted or clear coated is that dirt will get into the weave if you don't paint or clear coat and it is really difficult if not impossible to clean it. It will take latex paint real well, however the latex will need a clear coat to fuel proof it. Good Luck, Dave
