Aviation Fuel
RE: Aviation Fuel
Give your local airport a call. Your going to need to talk to an FBO (fixed based operator) and he can guide you. When you do go to the airport bring what ever fuel jug you wish you have fuel put in. Make sure the fuel jug has at least a 1 and a half inch opening, nozzles used for fueling are larger then those of your normal gas station. The other thing to remember is precision its not easy to fill a small jug with inch and a quarter nozzles at 10-15 psi requires time, you may want to tip the person serving you. Why do you need this fuel?
RE: Aviation Fuel
ORIGINAL: ktreadway
Just a thought, but why do you need Aviation fuel?
RE: Aviation Fuel
Boat gas or thats what they call it in Minnesota , is non-oxygenated and 92 % octane . I used it in my motorcycles andsmall 2 strokeengines. The biggest plus for using non-oxygenated fuel , IMHO is it does not evaporate as fast as oxygenated . So if you have an engine set for a few months, the fuel doesn't evaporate and leave the film or additives thatall gas manufactures add totheir fuel to make it their own ..
Living in Minnesota , there are times my stuff sets for 6 months ,before I started using non-oxygenated fuel, I had to drain all the stuff that was going to set awhile or the fuel would evaporate and leave a greenish film behind. These small carbs have very small passages and areas the fuel well set and using regular pump gas, it doesn't take long for it gum up a carb.
I do motorcycle repair and most my work is cleaning carbs, most my clientèle has switched to non-oxygenated gas , good for them ,bad for me lol Idon't have to clean their carbs every year. I have had a couple come back , but after spending $250.00 to $300.00 for a second time , they switch.
FAI is non-oxygenated also ,but I believe it has a much higher octane rating, sry I just can not remember for sure 101. I think , but someone here well know for sure. Not sure what your engines compression raito is , but if it's high , it might not like a higher octane .. But if you want to try the Boat Gas , just type in non-oxgenated gas or check with your local Streetrod Clubs, most have a list of stations that carry it.
RE: Aviation Fuel
You can also ask a large operator, or a large maintenance operator for his left over fuel samples at your airport......you run the risk of getting water and such in your fuel,,,but if the samples were taken correctly you sump fuel tanks until you get a good sample...keep that sample until the next flight......
Or go to the fuel farm where they take daily samples.....again through the FBO
RE: Aviation Fuel
Why is it illegal.....Jet A/A-1 is not as dangerious as gasoline...just high grade kerosene...
I would think it would be illegal if you didn't have an approved container though
My Feedback: (-1)
RE: Aviation Fuel
Airport, I used to get my drumbs filled when I was still racing sand dragsters and they quit using lead. In small engines it's just a lot simpler to go to your small engine repair shop and buy the new alcohol safe carb kit. They cost a couple of bucks and take about two minutes to install. Think of all the time and money your friends would save not having to go to the airport to get there gas. Not all airports will sell to people using cans, I had 15 and 55 gallon drumbs.
RE: Aviation Fuel
The current 100 low lead blue for what its worth is only a lower lead content than than the old 100/130 Av Gas green and still has very high lead content even a little higher than than 80/85 red which is harder to find now.
Be aware many FBO's who would sell av gas dispensed into small containers to drive in customers will not after 9/11. Best to call first.
John
John
RE: Aviation Fuel
ORIGINAL: jetmech05
When you buy normal gas your paying 'road taxe'. You do not pay these taxes when buying aviation fuel. Its a tax thing. FBO's cant legally sell it to you if they believe it will end up in a road vehicle.
Steven
RE: Aviation Fuel
After having lots of Walbro carb problems using the alcohol laced gasoline, I have been running Colman camp stove fuel for the past two years. Works as well as gasoline along with less problems with odour and no more carb problems. Costs a bit more but still cheaper by far than glow fuel.
My Feedback: (-1)
RE: Aviation Fuel
ORIGINAL: Rodney
RE: Aviation Fuel
I have been using regular gas in my gas engines from 50cc up to 100cc and have not had a problem with ethenol. I have contacted Desert Aircraft about the use of Avgas and was told if you do so it will void the warranty. All of your weedeaters and other two strokes run just fine on pump gas. If you were to set the engine on the shelf with gas in it for a extended period of time it would probably dry out the gaskets, hoses, and so forth. but if the engine is used on a normal basis I personally see no benefit in paying the extra money for AvGas, or taking a chance on one of my engines or the warranty
