Reload this Page >
Major Sig somethin extra engine problem
Old 03-25-2010, 09:23 AM
LargeScale88
LargeScale88's Avatar
Default Major Sig somethin extra engine problem
I'm mounting the engine for my sig somethin extra. I have serious problems:...
1) The engine hangs wayyy out past the fronts of the fuselage sides
2) my throttle is going to be tricky, (dont' know how to fix it
3) INEEDHELP!!!!!!
Old 03-25-2010, 10:21 AM
MinnFlyer
MinnFlyer's Avatar
Default RE: Major Sig somethin extra engine problem
What Engine?
Old 03-25-2010, 05:12 PM
p100d
Use a cable you can run the plastic tube as far out as you need and the cable still works well. The times I have done this the tube doesn't melt from the engine heat. Good luck.
Old 03-25-2010, 07:15 PM
LargeScale88
Ive got a saito 56 for it. Very hard to hook up the throttle for a 4 stroke.
Old 03-25-2010, 10:06 PM
ChuckW
ChuckW's Avatar
Try running the pushrod out and making a U-bend back toward the throttle arm. You could also try a Du-bro 4-stroke linkage: http://www3.towerhobbies.com/cgi-bin...?&I=LXD939&P=7
Old 03-26-2010, 06:51 AM
LargeScale88
Ok thanks. I ordered that four stroke linkage! Should work very well!
Old 03-26-2010, 08:31 AM
MinnFlyer
MinnFlyer's Avatar
You can just use a long bend in the throttle pushrod and go directly into the arm, or through an EZ connector
ID:	1405199   Click image for larger version
Old 03-26-2010, 09:08 AM
LargeScale88
Ok thanks minn. I just got all the servos mounted, and the engine, so I will be working hard on the throttle.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
