Reload this Page >
Throttle reversing
Throttle reversing
Old 03-30-2010, 02:32 PM
Rcflyer30
Default Throttle reversing
Hi.
I recently bought a Tower Pro motor that I put into a mini telemaster. The problem I am having is that the throttle is reversed. In other words, the throttle stick must be up and moved down to start the motor and increase speed. It is backwards of the way it should be. I tried switching the servo setting on my transmitter, but that did nothing. I am using an old Tower Hobbies 3000 transmitter. If anyone could help me it would be appreciated. Thanks, Seth
Old 03-30-2010, 02:37 PM
MinnFlyer
MinnFlyer's Avatar
Default RE: Throttle reversing
Try switching it again and make sure it is reversing and not going back to "normal" when to leave the programming mode.
Throttle should be Ch 3.
Select Ch 3, note its direction in the Transmitter, Reverse it and try it. If it's still backward, go to ch 3 again and see if it went back to "normal" somehow.
Old 03-30-2010, 04:38 PM
Rcflyer30
Thanks. That does seems to do anything. Any other ideas?
Old 03-30-2010, 04:43 PM
MinnFlyer
MinnFlyer's Avatar
Can you move the servo arm to the other side?
Old 03-30-2010, 05:27 PM
Zippi
My Feedback: (10)
Zippi's Avatar
Rcflyer30,
If all else fails then relocate the throttle servo and use the other side of the servo arm.
Old 03-30-2010, 08:13 PM
Ed_Moorman
Ed_Moorman's Avatar
I don't know much about electrics, but a buddy mentioned that to reverse a motor, you swap any 2 of the motor leads.
Glow, I know, but electrons don't know which way they are going.
Old 03-30-2010, 09:03 PM
MinnFlyer
MinnFlyer's Avatar
Reversing a servo is only slightly more complicated, and some are too difficult to do at all
Old 03-30-2010, 09:05 PM
JohnBuckner
JohnBuckner's Avatar
Can you confirm how you are reversing the Tx? On that Tx there is a tiny clear plastic door on the front side that slides open to revel four or six tiny reversing dip switchs you normally use a small screw driver since they are so small. You need to move the position of the switch marked either TH or CH 3 to the opposite position it is now and you should feel a click or solid stop after it moves.
John
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
