UFO foamie
Old 03-31-2010, 06:34 PM
treetopflyer54
Default UFO foamie
hi can someone help me to program this thing? I'm using a dx6i radio with a ar6110e receiver, and I cannot get the aile,rudder elev,programming to work properly thanks Don my email is [email protected]
Old 04-02-2010, 08:59 PM
Bonified Wingnut
Bonified Wingnut's Avatar
Default RE: UFO foamie
You really need to give a bit more info...maybe a picture.-BW
Old 04-02-2010, 09:14 PM
treetopflyer54
sorry, this plane is a vfo by great planes, looks like a rocket with 4 wings.
Old 04-03-2010, 03:49 AM
Bonified Wingnut
This is a from the manual-
"2. This airplane requires the use of a couple of different
mixes. With the large number of different radios on the
market it is impossible to provide exact instructions for all
of them so we have attempted to give you the basic mixes
you will need to set up the VFO Pogo. You will need to refer
to the instruction manual for your radio to understand how to
achieve the mixes explained here. You will fi nd it helpful to
refer to the photographs that follow in the next section."
The manual is pretty vague and I don't know your radio I will help the best I can.
From what I see you need to set it up with elevons, use two different channels for the rudders and mix them, and then mix them with the aileron channel. I don not see a need for the Y harness described in the manual unless you use a 4 channel.
[link]http://www.youtube.com/watch?v=RoY4s0Oeuv8[/link]
That is an instructional video from Hobbico. Hope this helps-BW
Old 10-27-2012, 03:43 PM
DanDanFielding
The reason I purchased the Spektrum DX-8 was because of the SD card and the ability to copy or download model programming. I am having zero luck programming my Great Planes VFO foamy. Is ther anyone out there who could post a copy of working programming code for this plane for the DX-8. The file could be coppied from the SD card and would probably be named. "VFO_.spm".
I hope in the future model manufactures will include a copy of the programming code for the products they sell.
