Reload this Page >
High voltage servos
High voltage servos
Old 04-01-2010, 09:35 AM
Quigleywins
Quigleywins's Avatar
Default High voltage servos
My question relating to this topic is how are they powered through the reciever that operats on 4.8 volts .How do you use a S2 batt and not blow the reciever.[&o]
Yours Paul T
Old 04-01-2010, 10:02 AM
KW_Counter
Default RE: High voltage servos
Check with the manufacturer of your receiver as to what voltage is safe.
It is my understanding the servos are more of a problem with high voltages.
There is a forum here for Radios & Electronics where the manufacturers monitor
their sub forums. Here is the link:
http://www.rcuniverse.com/forum/forumid_157/tt.htm
Good Luck,
KW_Counter
Old 04-01-2010, 10:28 AM
BarracudaHockey
BarracudaHockey's Avatar
Many receivers can take the voltage, check the specs of the reciever.
If you run a 4.8 volt pack, then whatever voltage you send to the reciever is what the servos are going to get.
If you dont feel like messing with a lipo and regulator, just run a 5 cell battery, its safe for just about everything out there.
Old 04-01-2010, 12:01 PM
exeter_acres
exeter_acres's Avatar
the RX has a built in regulator to regulate the voltage to actually power the RX....
the servos are on a power buss and whatever voltage goes in, is passed on to the servos.
Old 04-01-2010, 03:25 PM
The Ghost
The Ghost's Avatar
The High voltage servos are designed to be used with the new 2.4 gig receivers that can take the higher voltages.(Spectrum{9.6volts} and some of the high end JR's) are some that I know. The will still work with normal setups but may be slower that stated.
Cheers
Old 04-01-2010, 06:58 PM
Edwin
Use this. http://www.servocity.com/html/servo_power_boards.html Thats the cheap version. It isolates the power from the receiver. You provide whatever battery you want for servo power.
Edwin
Old 04-02-2010, 06:38 AM
Quigleywins
Many thanks for all the top information. I intend runing my Spektrum 2.4 system with the DS378 servo. On looking into the servo I noted they make a High voltage unit and was wondering how they were connected to a reciver so hence the question. I run 6volts already but wondered what would happen to the reciver with the S2 batt . with all the good information I will do some more research and may be back with more questions. Again thanks for the quick information Yours Paul T
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
