Reload this Page >
How to Test servos
How to Test servos
Old 04-03-2010, 10:23 AM
trpastor
Default How to Test servos
How do you go about doing good testing of servos (torque speed etc)? so that you can find out thier true specs?
Tim
Old 04-03-2010, 03:17 PM
Lnewqban
Lnewqban's Avatar
Default RE: How to Test servos
Tim,
I would use a pulley and string and weight, as represented in schematic.
Torque (in-oz) = Radius around which the string wraps (in) x Weight (oz)
Max torque will happen at stall condition (the weight does not move or it does it very slowly).
Now, to test specification's rotational speed ( x sec/60°), you can use the same layout plus the vertical scale and a stopwatch.
Just measure the time it takes to move the weight for the distance correspondent to 60 degrees ((Perimeter x 60) / 360).
Distance = (Radius around which the string wraps (in) x 3.1416) / 3
For more accurate time measurement, a longer radius is better.
I am not sure under what load that specified velocity should be measured.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
