Reload this Page >
Nylon insert blind nuts
Old 04-03-2010, 11:56 AM
Deadeye
Deadeye's Avatar
Default Nylon insert blind nuts
Why doesn't anybody make them I wonder?
Old 04-03-2010, 01:07 PM
ChuckW
ChuckW's Avatar
Default RE: Nylon insert blind nuts
It would be a neat idea. Of course, you could only put the screw in and out a few times before the nylon becomes ineffective and the blind nut needs replacement but that's fine. They'd be nice for landing gear and engine mounts.
Old 04-03-2010, 03:04 PM
big max 1935
My Feedback: (9)
Check at a parts store for some Lock-tite. Comes in different colors for different uses . I us the blue ,holds but you can remove the bolt or nut. Max H.
Old 04-03-2010, 03:42 PM
Deadeye
Deadeye's Avatar
ORIGINAL: big max 1935
I know about and use loctite. Nylon inserts would be so much cleaner.
Old 04-03-2010, 03:50 PM
ChuckW
ChuckW's Avatar
Yep, been using Locktite for many years on everything from automotive to RC. Ny-locks do work well for certain things though.
Old 04-04-2010, 07:10 AM
MinnFlyer
MinnFlyer's Avatar
Technically, nylon lock nuts are only supposed to be used once. I think that's why no one has put them into a blind nut - not to mention the difficulty involved
Old 04-04-2010, 09:55 AM
big max 1935
My Feedback: (9)
They do make a all steel lock nut that can be used over. It could be soldered to a tin or brass plate & that held to the rear of the firewall with small screws. The nylon insert would melt from heat if soldered .
Several aircraft I used to work on in my old AF days used a nylon nut held in a stamped alumimnum holder that was riveted to the ac frame with one or two rivets . Never did see any changed over the years but they were not in any high vibration areas ,mostly just a tough place to put a nut on . " Keep em flying " Max H.
Old 04-04-2010, 12:19 PM
ChuckW
ChuckW's Avatar
ORIGINAL: MinnFlyer
Those would be the two biggest issues. they would have to be replaced now and then if used for something that comes apart a lot and it would be a pretty complicated, expensive little blind nut. Would be a nice option to have now and then though..
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
