Pushrod of 1mm Diameter... Where can I find it?
Hi all,
I'm building my own F-22. I purchased 4 of these servos. The holes on the plastic arms have a diameter of 1 mm. I'm looking for a 1mm pushrod which is also at least 40cm long, but I'm enable to find it. Could you help me? I'm in Turkey and I want to purchase them from USA or from Hong Kong or China. A set would be better than just a pushrod, but all welcome...
M. Besir
M. Besir
RE: Pushrod of 1mm Diameter... Where can I find it?
Just do a Google search and you should find some sources. This one in England comes up: http://www.indoorflyer.co.uk/20swg-x-1m-091mm-261-p.asp
Also, is there enough material to just drill out the hole a little without sacrificing strength? Then you might be able to use a more readily available wire.
I think drilling will reduce the strength. 1mm rod is also not quite well for my F-22... I'm searching but I'm confused at some points. For example I don't know which part is 2mm in "2mm clevis". I think the rod that will be connected to a "2mm clevis" should have 2mm diameter, but what about the pin that will be connected to the horn? Is it also 2mm? Due to this stupid questions I'm looking for a complete pushrod set ... Thanks for your time.
