inverted Saito 100
RE: inverted Saito 100
ORIGINAL: mpspx8
Should a inverted Saito 100 need a onboard glow system?
And yes, the power is perfectly adequate for scale flight.
Best wishes,
Dave Olson
My Feedback: (47)
IL
Your Saito 100 will start and run just fine inverted as long as you cover the basics. OS-F glow plug, fuel tank height within acceptable limits, you properly tune the low end needle, and use good fuel.
I sort of prefer to run my 4 strokes inverted as they are easier to prime and once the sequence is learned they can be started with one or two back flips of the prop.
Fred
Fred
NS, CANADA
I used my Saito 100 inverted from the day it was new and I used pro 20-20 fuel and swinging a 14x8 prop with no problems at all and going into it's second yesr it is still running perfect
good luck and safe flying.
