Thunder tiger windstar ep help
PA
I have a thunder tiger windstar glider and need help figuring out what motor to put in it. I am hearing the stock motor is not that great.
Any help is appreciated.
Scott
Scott
IN
If you are still needing help, here are links to the motor, esc and batt, I just put in my Windstar. With the prop that came with the plane, this system is powerful enough to climb at a decent rate. The plane even handled some 20+mph gusts last week. I placed the battery under the hatch instead of under the wing, so I wouldn't need to add nose weight. It might be a little late, but I hope this helps.
http://www.hobbypartz.com/dynam50aair.html (50 amp esc)
http://www.hobbypartz.com/75m21-opti...10-1020kv.html (brushless motor)
http://www.hobbypartz.com/77p-sl2200-3s1p-20c-3333.html (lipo battery)
