Gas:oil ratio...and I'm confused
My Feedback: (8)
I have a 43cc Fuji gas engine, it's my first gasser. I bought a bottle of Fuji oil (4.23fl.oz. (125ml)) premixed at 100:1. It says dump it into a 5 gal. tank and add 5gal. of gas. I did some math and both ways, oz.'s and ml's, and came up with 151:1.
Anyway, lets say Fuji is correct (it probably is), the first stage of breakin on my engine is 50:1 (higher oil content?), so would I dump all the 100:1 premixed into a 2.5 gal. container for 50:1?
This might just be ANOTHER senior moment.
RE: Gas:oil ratio...and I'm confused
Not much good at maths myself, but this might help: http://www.csgnetwork.com/oilfuelcalc.html
IA
If you have 4.23oz of oil and you want 50:1 then 4.23oz X 50 = 212oz of gas (1.65 gallons) plus the oil. The 100:1 would be calculated the same way 4.23oz X 100 = 423oz (3.30 gallons) plus the oil.
Your math was correct. Perhaps Fuji meant 3 gallon tank.
Stan
Stan
My Feedback: (8)
Thanks for the link, but it came up with 6.4oz oil for 50:1 in a 2.5gal of gas. The Fuji oil is synthetic so I'm wondering if that is the difference.
I have used nothing but STIHL high performance oil for years in all my gas burners . Comes in a 2.6 oz bottle that mixes with 1 gallon of gas. Never a bit of trouble . Max H.
I do the same as above, bought a bottle of oil for a mix with 5ltrs of fuel to give the required mix, then kept the bottle and then bought a 5ltr can of oil and then use the bottle as a mix measure from the bulk oil, saves a lot of time, again I only mix 5ltrs at a time so it does not go off, also use the same fuel in the mower and weed eater.
Cheers
Cheers
ORIGINAL: dbcooper14
Better oils allow higher mixture ratios.
The label is not correct, your calculations are correct.
If the actual capacity of the container is 4.23 ozfl (125 ml):
The label should read "Pre-measured to mix with 3.3 (12.5 liters) gallons of gasoline".
Or it should be labeled 150:1 mixture ratio, like the 250 ml container is:
http://www3.towerhobbies.com/cgi-bin...&P=SM&I=LXHAL0
Just follow the instructions in your engine's manual:
Break-in (Stage 1): 1 gallon of gasoline with 50:1 (2%) oil content ratio. (2.560 ozfl/gallon or 20 ml/liter)
Break-in (Stage 2): 1 gallon of gasoline with 100:1 (1%) oil content ratio. (1.280 ozfl/gallon or 10 ml/liter)
Normal running: In un-cowled or well-cooled installations 150:1 (0.65%) oil content ratio. (0.832 ozfl/gallon or 6.5 ml/liter)
In-cowled or not-so-good cooling installations 100:1 (1%) oil content ratio. (1.280 ozfl/gallon or 10 ml/liter)
