How often to charge my DX-7?
HI,
I'm always confused as to when to charge my transmitters. I don't want to have the TX battery develop memory or ruin the battery by charging it too often, or for too long. How does that factory charger work anyway? CAN you overcharge the Tx battery? At what voltage should I decide to charge it? 9.9v? I have a DX-7 right now but for 15 years have always wondered about this.
What do you guys think?
Moderator
RE: How often to charge my DX-7?
If you're using the wall wart that came with the transmitter just plug it in for about 10 hours before you go flying once you've done your initial form charge of 15 hours. The battery can tolerate some overcharging at that slow rate, and memory isn't going to become an issue. You can cycle your battery down to 1.1 volts per cell every few months if you're still worried about memory, but NiCd's have improved over the years in that area so it's really not an issue anymore. Cycling on a good charger 2-3 times a year is good to verify that the battery is still taking a charge like it should.
Charge it the night before you go flying... every time. I see a lot of guys with their flying days ruined because they show up with a dead transmitter or receiver battery. The battery that comes with it is NiMh so memory effect shouldn't be an issue.
FL
I upgraded to the 2500Mah battery in my DX 7 last year......full charge on that bad boy and I can go all weekend at the field....at least until the Wife sends someone to get me
http://www.horizonhobby.com/Products...rodID=JRPB5011
My Feedback: (-1)
The battery that is in mine {that needs replacing} gets charged as soon as I get home from the field and my charger goes into trickle mode so it is always ready. It's set to beep around 9.2 volts I think?? Anyway, today I got it down to 9.3. If I was going to fly more I have a field charger and in about 20 minutes it's good to go again. When I was using the wall warts some years ago I charged up every night before I went flying.
