Prop balancing
Old 07-21-2003, 12:08 AM
listed
Default Prop balancing
I have a magnetic prop balancer and I can get the prop balanced one way so that it stays where ever I put it, but if I remove the prop turn it over 180 degrees then sometimes it show it is out of balance again. Am I doing something wrong or is the hub heavier on one side??
Thanks for any help.
Les
Old 07-21-2003, 02:02 AM
MinnFlyer
MinnFlyer's Avatar
Believe me, if you have it THAT close, it's plenty close enough!
