Best linkage??
My Feedback: (44)
GA
Best linkage??
Can anyone tell me what is the best linkage to use for control surfaces on 1/4 scale. Thinking of using 4-40 rods and ball links...appreciate any advice..Thanks...Mike..
FL
RE: Best linkage??
ORIGINAL: Spiritwind
I like ball links too, and 4-40 rods should be fine on
a 1/4 scale. IMO,
Bob
RE: Best linkage??
That's what I use. But when you say "best" you will get guys telling you the titanium threaded stud carbon fiber rods are necessary. Next best is probably a 0.095" rod with "Z" bends at exactly the right spots on both ends. Zero failure points but prone to slop from continued wear.
I like the horn end to have a silver soldered clevis and the ball link on the servo arm. A rod with adjustable ends on both ends can accidently loosen with vibration and use. A single adjustable end is trapped and cannot.
RE: Best linkage??
The 4-40 ball links are great. Where possible though (which is almost always) , I go pull-pull on the elevator and rudder. A properly installed pull-pull is far more reliable, slop free and easily variable in throw and location.
RE: Best linkage??
The linkage you described is fine. I've used Z-bends and pull - pull in large scale aircraft and if done correctly they work fine. The only thing I don't use is the EZ-connectors, except on the throttle.
