RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   servo buss (https://www.rcuniverse.com/forum/questions-answers-154/10011292-servo-buss.html)
rye 09-18-2010 06:01 PM
servo buss
hi
ok i just about got rid of the servo buss in the rud, thr, ele but it comes and goes all i have to do is tap the sticks and it stops ,is there any other tricks you guys use to make them buss free? thanks
huck1199 09-18-2010 06:21 PM
RE: servo buss
I assume you mean buzz. Are they digital servos?
rye 09-18-2010 06:25 PM
RE: servo buss
ho reg ones and yes buzz
huck1199 09-18-2010 06:28 PM
RE: servo buss
If you move the radio 10 feet or more away from the plane does it still buzz?
rye 09-18-2010 06:29 PM
RE: servo buss
yes
huck1199 09-18-2010 06:31 PM
RE: servo buss
Is there any binding in the control rods or the surface hinges?
rye 09-18-2010 06:34 PM
RE: servo buss
no i play with the trims up or down a little and it stopped but when i move the stick it comes back and then i tap them a little and it stop again would thw motor running help this ?
huck1199 09-18-2010 06:38 PM
RE: servo buss
Can you swap the RX out and see what happens? It is not likely that all the servos are bad.  Another thought; were all the servos set to nuetral position when you hooked the control rods?
rye 09-18-2010 06:40 PM
RE: servo buss
ill try that tomorrow and yes they where all in nuetral before they where hook up to the arms
huck1199 09-18-2010 06:44 PM
RE: servo buss
Are you over powering the servos?  Meaning 6 volts on servos that can only take 5 volts?  If none of the conditions mentioned so far exist there is probably nothing to worry about if they seem to work properly.
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
