RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Great Planes Hinge Slotter - what power (https://www.rcuniverse.com/forum/questions-answers-154/10016411-great-planes-hinge-slotter-what-power.html)
WilliamT 09-20-2010 10:19 PM
I recently purchased a Great Planes Hinge Slot tool through Tower Hobbies.
However, I live in a country where the standard voltage is 230v not 110v, so will need to purchase a transformer before I can use the Slotter. These are available here in a range of VA values with a corresponding range of prices!
Can anybody please tell me the VA rating or the current draw of the Slotter, as Tower are unable to supply that info?
William[:o]
summerwind 09-20-2010 10:23 PM
RE: Great Planes Hinge Slotter - what power
mine says
120VAC 50-60Hz
no mention of current draw
DMcQuinn 09-20-2010 10:30 PM
Mine does not say how many Amps is draws on the label. It says "120 V 50 / 60 Hz". I would guess it uses less than one amp (100 watts), just by looking at it.
tacx 09-20-2010 11:02 PM
If someone out there has this slotting tool and a Amp meter they can easily check the amp draw for you.
WilliamT 09-21-2010 12:08 AM
Thanks for the comments, folks.
To summerwind and DMcQuinn - yes, that's the trouble with the label - it doesn't specify Watts as you would normally expect.
To tacx - I imagine there aren't too many of these around in NZ but I will try on a local forum., something I had not thought of. Thanks.
I can't plug it in to test for myself, because I expect that our 230v would cause overheating or other failure of the tool!
Thanks again,
William
airbusdrvr 09-21-2010 05:55 AM
Do persevere, when you get it powered you will enjoy how easily the slots are cut.
drube 09-21-2010 06:52 AM
I just picked up one of these yesterday. In the instruction manual under the specifications it gives info for a North American model (110/120 v 60 Hz AC) and aEuropean model (220/230 v 50 Hz AC). That's all the info it says but you could contact Great Planes at [email protected].
http://www.rcuniverse.com/forum/js/f...sn/biggrin.gif
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
