RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Do I have a bad reciever (https://www.rcuniverse.com/forum/questions-answers-154/10023167-do-i-have-bad-reciever.html)
shurlock1 09-23-2010 08:14 PM
I have a FUTABA T6EXAP and a GWS reciever both using the same channel. I cant get my channel 6 to work for my aileron on the left side servo doesnt work but the other side works. I switched servos and have the same problem. I cleared the memory in the radio I also unpluged battery to esc waited a while and plugged back in and channel 6 still doesnt work. Does anyone have any ideas? Thanks Joe
abaser 09-23-2010 08:20 PM
RE: Do I have a bad reciever
Are you using ch6 for mixing or for aileron setup? unless your trying to use 6 for a mix you should be using i believe ch 1 for the right stick.(may be ch 2 Im not sure how they are labled)
shurlock1 09-23-2010 08:51 PM
I am using 6 for aileron
cpt nj 09-23-2010 09:42 PM
It might be somthing simple, make sure that your servo connection is correctly pluged in. Secondly I would test the servo seperatly. Is there a reason your not useing a Y harness ?
shurlock1 09-23-2010 11:06 PM
I tested everything by itself I am wondering if its a radio problem.
ScottMcM 09-24-2010 02:58 AM
To be able to use channel 1 and 6 for ailerons, don't you have to turn the "flaperon" option on? Otherwise, you need a Y harness, and run both ailerons from channel 1.
shurlock1 09-24-2010 05:50 AM
Is that with a 72 mhz radio also?
ScottMcM 09-24-2010 05:56 AM
Yep, at least with my 72mhz radios. It should be under "wing type". There are several options. Choose "flaperon"
shurlock1 09-24-2010 06:28 AM
Thanks for the help that done now I just have to reverse an elevator servo. Thanks again
