How to replace clip that holds needle valve
I have an ASP ( Magnum ) FS61AR and the clip that holds the needle valve from spinning is broke off. I have the peice that broke off... Is there a way to fix that ... No one around here has the replacement part... Any one have an address for the new piece or Ideas for a way to stop the needle valve from moving... High end valve. Thanks
Put some fuel tubing over the fitting, then screw in needle valve. That will prevent it from turning.
Fuel line trick works great. If you want it to look stock you can find a shirt pocket clip from a disposable pen.
Originally posted by chuck_zc Fuel line trick works great. If you want it to look stock you can find a shirt pocket clip from a disposable pen. I second this fix. Works great. Pete |
Thanks all... easy fix and needle valve is inside the cowl so can't see that part...
