Duct fan ?????????? OK MODEL TYPE II
I have a complete ducted fan set up in great shape
Its is OK MODEL CO. DUCTED FAN UNIT TYPE II 90mm 5 blade rotor & 6 element stator it comes complete with a .18nitro engine apprx rpm 25000 tune pipe says it deliver apprx 2.4lbs of thrust does any one have an idea of what jet and weight this will work in?? Thanks |
RE: Duct fan ?????????? OK MODEL TYPE II
The fan did come with OK Models DJ-1 and DJ-3 airplanes.
From their website DJ-1: Lenght: 894mm Wingspan: 1000mm Wing area: 32 square decimeters Weight: 1100 to 1200 grams DJ-3 Lenght: 1310mm Wingspan: 937mm Wing area:28 square decimeters Weight: 1500 to 1700 grams The fan should then be able to fly somethting similar, I would opt for a model close to the light one. Go to okmodel.co.jp and type DJ-1 in their search window. (Hit and miss, it's mostly all japanese but the numbers and measurement are possible to comprehend for us that dont understand japanese, as is the pictures.) |
