need help locating offset hinges
some times back I have seen offset Plastic gear door hinges advertised, not the Alu type from Robart. I cannot find this
source again. Has anyone seen them, I believe they cost around $ 4.95 a pair. thanks. Buchtes |
RE: need help locating offset hinges
I can't find the ones that I have, but I believe they were made by "Foremost".
Les |
LesUyeda; A search at Fourmost, not Foremost, turned out negative, they have hinges but not offset, thank you. Buchtes
Try wing Manufacturing; I think they sell them at Toledo each year.
ORIGINAL: R8893 Try wing Manufacturing; I think they sell them at Toledo each year. I got mine from Wing, too. |
I cannot find any offset hinges in Wing Mfg.'s Catalog, only speed hinges??
Buchtes |
Call 'em. They sell them at swap meets, so they should have them in stock.
I sent a e-mail to Wing Mfg. about the Hinges, thank you all very much.
Buchtes |
the Hinges are on order, thank you all
Buchtes |
| All times are GMT -8. The time now is 11:42 AM. |
