RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Pluming from tank to engine (https://www.rcuniverse.com/forum/questions-answers-154/10309714-pluming-tank-engine.html)
cotman 02-03-2011 11:35 AM
Baught a used OS FS120 surpass engine. Not sure how to plum it from the fuel tank to the engine. Can someone send me a diagram so I can follow. Thanks
MinnFlyer 02-03-2011 12:26 PM
RE: Pluming from tank to engine
It should just plumb like any other engine. Are you using a 2 or 3 line system?
cotman 02-03-2011 02:23 PM
using a 3 line system. This engine has a pump
smithcreek 02-03-2011 03:26 PM
One fill line to the tank, one fuel line from tank to engine and one vent line. The vent line is the same as you would usually use for the muffler pressure, except you don't need muffler pressure with the OS 120 pumped. I plug the vent line when I'm storing the plane but you need to leave the vent line open when filling the tank and when the engine is running.
Lnewqban 02-03-2011 08:53 PM
1 Attachment(s)
Cotman,
Follow the instructions in the manual:
http://manuals.hobbico.com/osm/fs-120s-iii-manual.pdf
Gray Beard 02-03-2011 09:12 PM
From the fuel tank main to the pumps IN, it's labled. from the pump OUT to the engines carb. The pumpers require a vented tank so line #3 {vent} requires no cap.
