Progamming the Futaba 7c - "digital" rudder
Ok. I want to program my Futaba 7C to control two micro switches. They will be used to turn on some electric components.
I want to use one servo on channel 7 using the "G" switch. I want it to work just like mixing in a second rudder, but WITHOUT tying it to the rudder channel. In short, when the "G" switch is in the center position, I want the servo at neutral. With the "G" switch in the top position, I want the servo full right, with "G" in the bottom position I want the servo full left. This is "easy" if I also tie channel 7 to channel 4 or 1, but then the servo moves as the control stick is moved. The switch only engages or disengages the mix. I want the switch to control the position of the servo. I don't think it's possible. Futaba left off the "set center position" adjustment unless you tie the channel to another channel. I want this to be an OFS mix. Any ideas? |
RE: Progamming the Futaba 7c -
Sure, go the AUX CH menu, set the channel your trying to control to the G switch
Might be under parameters, I forget the menus on that radio |
That would be sweet if I knew where that menu was. There is no reference to it in the manual and I cannot find it while going through the menus on the transmitter.
Thanks for trying, though. |
My apologies and thanks. I looked under Parameters and found the switch setting for Ch7. Changed it to "G", and got exactly what I wanted, no mix, no fuss.
Thanks again Andy. |
My pleasure, happy flying
