RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Wacos (https://www.rcuniverse.com/forum/questions-answers-154/1069509-wacos.html)
Cuda3 08-19-2003 01:47 PM
Wacos
Have a 60 size ARF Pico Wacos that keeps going up ...... even with full down elevator. CG is right - Stabilizer does not seems to be level ???? Could this be the cause???
waagbuck 08-19-2003 02:45 PM
downthrust?
Could your engine thrust angle be off?
Cuda3 08-19-2003 02:48 PM
Wacos
I am not sure ..... What would a corrective action be ....... Down thrust or up thrust ???????
waagbuck 08-19-2003 04:06 PM
downthrust
If you have too much upthrust, which is one guess for this problem, you would angle the engine downard relative to the line of flight. THis is accomplished very easily with a washer or two in between the firewall and the engine mount. For downthrust, install washers behind the upper two engine mounts. Add more washers for more downthrust.
FLYBOY 08-19-2003 05:27 PM
Wacos
How is the incidence on the wings? Is it way off?
jneesy 08-19-2003 05:29 PM
Wacos
wing incidence would be my guess . does it change with throttle settings ?
Cuda3 08-19-2003 06:54 PM
Wacos
Lower wing is 0 and top wing is +2 degrees ........... At slower speed it does not raise as fast
FLYBOY 08-19-2003 06:58 PM
Wacos
How far off is the horizontal stab? That little bit of diff in the wings could be some, stab off could be more, neg incidence in the engine could be more. All added up could pose a problem.
Miloh 08-21-2003 10:34 PM
Wacos
there was a post before on this same bird, seems that the struts that hold the top wing are not marked well and can be put on backwards causing the incidence of the top wing to be off enough to cause a drastic climb. do a search on waco and you should find it.
Miloh.
