Canopy Material
Have to replace a canopy made out of sheet plastic. The question is if I want to buy plastic sheet to have on hand to do this. What is the correct type of plastic to use and how thick should it be? What are the best suppliers to get it from? I try to use plastic from store packages which work great, but the best ones I found are in toy packages or X-Mas gift boxes. I don't have younger kids anymore (good excuse to buy the kids toys) and my supply is gone. Any answers?
RE: Canopy Material
2 or 3 liter soda bottles work great.
RE: Canopy Material
Typically .030 or .040 PETG
http://www.bing.com/search?q=PETG+Plastic&FORM=QSRE1 Call around you local plastic dealers,,, |
RE: Canopy Material
I buy mine at Hobbytown. It's K&S Engineering plastic sheets. The stuff I have been using is .010 and works very well. This company is located in Chicago www.ksmetals.com
773-586-8503 |
RE: Canopy Material
GB,, .010 is pretty thin,, you sure?
After re-reading the OP I was thinking vacuum forming not flat sheet I guess it depends on what you're using it for,, The bigger the pull the thicker you want it |
RE: Canopy Material
I have always purchased mine from SIG.....I think their largest size is 18 x 18. It's been quite a while since I have purchased any because I buy them a dozen or more at a time..
RE: Canopy Material
Thanks for all the fast answers to my questions. I'm on the way to order a few sheets to get the repairs done so I can fly this plane.
RE: Canopy Material
ORIGINAL: scale only 4 me GB,, .010 is pretty thin,, you sure? After re-reading the OP I was thinking vacuum forming not flat sheet I guess it depends on what you're using it for,, The bigger the pull the thicker you want it |
RE: Canopy Material
I never thought about using a large canopy to create smaller ones.....I have several large ones just collecting dust on the shelf.....Thanks for the idea!
RE: Canopy Material
ORIGINAL: sebo I never thought about using a large canopy to create smaller ones.....I have several large ones just collecting dust on the shelf.....Thanks for the idea! |
