Flaps
I have a dx8 with a AR8000 reciever and I am trying to setup flaps and gear but can't get it to work. I have cessna that has two servos for ailerons with a y connector and the same for the flaps and I would like to use the gear channel for a drop box. What do I need to do to get the flaps to work. I have played with the swith settings and port I plug the flaps into but nothing. ANy help?
RE: Flaps
Be sure to set the wing type to the one that shows ailerons and flaps each on one channel. Then in settings there is a screen for flaps that I think is set to inhibit by default. Enable that. There is another screen that let's you set travel for 3 position flap switch, and mix for elevator.
I forget which channel ends up being for flaps, but the monitor screen will show you. |
RE: Flaps
I got it. Since I was using a y-harness, I needed for the wing type to be 1 aileron and 1 flap.
RE: Flaps
Yep. Glad you got it.
| All times are GMT -8. The time now is 07:11 AM. |
