RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   balsa pushrods (https://www.rcuniverse.com/forum/questions-answers-154/10845224-balsa-pushrods.html)
lleach1 12-05-2011 07:20 PM
balsa pushrods
What is the best string or twine to use for wraping threaded rods on square balsa pushrods. I would appreciate hearing tips. Thanks LEL
Bozarth 12-05-2011 07:26 PM
RE: balsa pushrods
Basic sewing thread (many many times) and hit with CA.
Kurt
Pylonracr 12-05-2011 09:11 PM
RE: balsa pushrods
ORIGINAL: Bozarth
Kurt
+1
Have done it many times. Works great.
jester_s1 12-05-2011 09:13 PM
RE: balsa pushrods
As long as CA will stick to it, any string will become the strongest part of the pushrod. I use kite string because my daughter has about a mile of it.
JeffinTD 12-05-2011 11:49 PM
RE: balsa pushrods
Back in the day I used unwaxed dental floss on 1/2 a stuff. Kite string on larger.
MinnFlyer 12-06-2011 07:16 AM
RE: balsa pushrods
I also use plain ol' sewing thread. Always have, always will
GREG DOE 12-06-2011 09:48 AM
RE: balsa pushrods
I like a product called "Button Hole Thread". It's just a little thicker than regular thread.
mvallyman 12-06-2011 10:50 AM
RE: balsa pushrods
I too use floss, its always available. I use 30 min. epoxy brushed over it.
Gray Beard 12-06-2011 11:38 AM
RE: balsa pushrods
Sewing thread and CA. I'm seeing several things here that may be better but I have a spool in my drawer I have been using for decades. I don't often use balsa sticks for controls but I have in the past. I found carbon fiber arrow shafts a lot better and they don't warp over time or require bracing.
HighPlains 12-06-2011 04:57 PM
RE: balsa pushrods
Yeah thread works, but you can use a 1" wide strip of Monokote or Ultracote and just wrap and iron around and around about 3 or 4 wraps of covering. Works about like heat shrink tubing. Easy, quick, and cheap.
The important thing is to select firm straight grained balsa (or dowel rod) and to toughen up the hole where the metal pushrod goes through the wood with some CA.
JeffinTD 12-07-2011 12:49 AM
RE: balsa pushrods
The last kit I built had you build up hollow balsa pushrods from strips. They actually seem quite straight and stiff that way, especially for their weight.
DavidAgar 12-07-2011 06:22 AM
RE: balsa pushrods
I use regular sewing thred with thin CA to secure the rods to the push rod. I would recomend using at least 1/4 dowels for the pushrods as I have had a balsa pushrod break under a flight load and ruin a plane. Also the balsa sticks will flex and could cause you trim problems. Good Luck, Dave
lleach1 12-08-2011 05:50 AM
RE: balsa pushrods
A big thank you to all the guys who responded to my question about balsa pushrods. The outdoor sewing thread seems to work very well and took the CA quite nicely. I also have used kite string and non-waxed dental floss. The unwaxed floss is getting hard to find.
