futaba 9caps tx question
ok its been a few years since i been out the hobbie,but not all together. i would fly on ocasion not to loose my feel of the radio. well my question is, does anyone have a manual for a 9caps futaba radio. i have miss placed mine. i went to the futaba web site and it only offers a manual for the 9ch super tx. i just built a gp 300s 60 size, and i want to have flaperons. i cant remember how to program my tx so that channel 6 works as an ailiron and flaps. any help will be apreciated. i dont rember if i have to use ch6 and 7 or ch1 and 6. i have slept since then. i am also gona send my radio and several recievers back to futaba to have it calibrated, new batteries, etc. pm me if you have my answers. thanks charles.
RE: futaba 9caps tx question
Look in the 10CG manual....I went from the 9 Cap to the 10 almost 2 years ago and found the programming identical....down to trims...ie the same amount of trim went fron 1 radio to the other
Just about all futaba Manuals are here http://www.futaba-rc.com/downloads/manuals.html
The 9cap is a Big file,, http://manuals.hobbico.com/fut/9c-su...ies-manual.pdf Flaporon,,page 44-45 |
The 9CAPS is the 9C Super.
9 channel Computer Airplane PCM Super |
I lost, tossed?? Mine. I had to do the down load and print. Make sure your black cartrage is full!! My big gripe is all the odd ball set ups I have done over the years were stapled into my original book. All I wanted was airplane set up but I had to print the complete book. Someone that understands a putter better then me {Most everyone} should be able to just print what they need.
When you go to print you need to select the "Print Range", in your printer set up menu,, you want to select "pages from x to y"
ORIGINAL: scale only 4 me When you go to print you need to select the ''Print Range'', in your printer set up menu,, you want to select ''pages from x to y'' |
thanks for all your reply's my friends. well i am a little embarressed to say that, my wife went in my airplane building man cave and found it in less than 5 mins. i looked i promise i did. it was sitting right on top of all my old man magazines.(model airplane news that is.) she dont know about the other man mags i have tashed. thanks again guys. now its off to program. if any of you need any info out of it, pm me and will try to answer.
| All times are GMT -8. The time now is 02:30 PM. |
