Thick or thin?
I am building a fancyfoam 32 inch yak 55. I have both thick and thin foam safe ca, and I do not know what to use. I also have gorrila glue if that would work.
RE: Thick or thin?
Thin if there are no gaps between the two surfaces, thick if there are, and Gorilla in either case
RE: Thick or thin?
To fly right, you need these as light as possible. Use the thin, but be careful with the accelerator, too much will melt the foam. I don't like CA glues on my foamies, anymore. It makes the Depron brittle. I have started using UHU contact cement. DO not use the gorrilla glue. TOO heavy. JMO.
| All times are GMT -8. The time now is 08:07 AM. |
