RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   ESC throttle control (https://www.rcuniverse.com/forum/questions-answers-154/10911011-esc-throttle-control.html)
Syed Saad 01-15-2012 11:22 PM
<span style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(248, 248, 248); ">Hi. I have bought a hobbyking 20 amp ESC (</span>http://www.hobbyking.com/hobbyking/s...ontroller.html<span style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(248, 248, 248); ">). The red of battery is conncted to red of ESC and black to black.The throttle signal comes from the controller to white wire of ESC a 50 hz sq. wave with a 10% duty cycle(18 ms low,2ms high). The three output wires of ESC drives the motor. But the motor does not show any movement. What's wrong i am doing?</span>
huck1199 01-15-2012 11:44 PM
RE: ESC throttle control
Your product link is broken.  Are you using the correct sized battery?
Syed Saad 01-16-2012 12:02 AM
Here is my ESC
Here is my battery.Zippy flightmax 4400mah 3s1p 15c
<div>http://www.hobbyking.com/hobbyking/s..._3S1P_15C.html
The battery seems good to me. Because it gives 18 amp and the ESC i am using is of 20 amp.</div>
Steve Percifield 01-16-2012 05:06 AM
Just to make sure. You are hooking the 3 wire lead, with the servo plug on it, into the throttle port of your receiver, making sure it's polarity matches the receiver. When you power up, do you hear a series of beeps or tones from the ESC? The last series should be a series of 3 quick tones, indicating a 3 cell Lipo recognition. If all your wiring is correct, and you hear no tones, them check for loose connections or broken wires. If that is all ok, then you probably have a bad ESC. Return to Hobby King.
And make sure your battery is fully charged. The ESC might not be able to recognise a low battery.
Syed Saad 01-16-2012 07:51 AM
I am not using a reciever. I am dealing the ESC like the servo motor. The 50 hz wave(18ms high, 2ms low) goes to the white wire of the BEC. I hear 3 rapid beeps and when i connect the ESC and then beep after beep with a difference of about 8 to 10 seconds.
Steve Percifield 01-16-2012 08:20 AM
The beep after beep you hear is the same thing that happens when you pl;ug the esc into the incorrect receiver channel. It is not receiving the correct signal to operater. I have no idea how to help you with what you are doing.
exeter_acres 01-16-2012 08:28 AM
ORIGINAL: Steve Percifield
could be, but not always.. there are some setups.. that even if everything is correct...
when you plug it in.. it will beep.... until you apply throttle...
it is this way to remind the user that it is armed and ready to go.....
Syed Saad 01-16-2012 11:51 AM
Have any of you tried to control ESC with controller?
huck1199 01-16-2012 02:19 PM
Please describe what you are using to signal the esc.  Is it a signal generator?  If so it will have to vary thepulses to simulate rising and sinking throtle positioning.
Rodney 01-17-2012 05:46 AM
I think that the narrow pulse needs to be 1.5 milliseconds long or less, your 1.8 milliseconds may be to long a pulse for the low speed end. What is the repetition rate of the pulses? They should be about 20 to 25 milliseconds apart. The typical pulse size is 1.5 milliseconds plus or minus 0.5 milliseconds every 20 to 25 milliseconds.
Syed Saad 01-17-2012 06:12 AM
I am sigaling the ESC with the PIC microcontroller. A 2 ms high pulse is applied after every 18ms, like we do to control the servo.
huck1199 01-17-2012 12:28 PM
Could you use a servo tester to do what you want? Or are you trying to automate some process?  See this tester at HobbyKing
http://www.hobbyking.com/hobbyking/s...dProduct=11780
Redback 01-17-2012 12:50 PM
My recollection is that the control pulse should vary from 0.5 to 1.5mS depending on the control input. If you are feeding the controller a constant duty cycle pulse this may be the problem. Most ESCs will not arm if the throttle is not at low.
Check out this reference - www.omegaco.demon.co.uk/mectnpdf/mectn004.pdf
Terry
Syed Saad 01-20-2012 01:50 PM
<span style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(248, 248, 248); ">Thank you all.</span><br style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(248, 248, 248); " /><br style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(248, 248, 248); " /><span style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(248, 248, 248); ">Finally got my motor running. 19ms low pulse and then 1ms high. Repeated for about 5sec unless i heard a comparitively longer beep that comes when the ESC is armed. Then the on time was increased to run the motor.</span><br style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(248, 248, 248); " /><span style="font-family: verdana, geneva, lucida, 'lucida grande', arial, helvetica, sans-serif; font-size: 13px; background-color: rgb(248, 248, 248); ">My next target would be to control it's speed by a pot.</span>
huck1199 01-20-2012 02:58 PM
Sounds interesting. Can you tell us what you are constructing? I am interested in embedded systems and pic controlers.
Syed Saad 01-21-2012 01:03 PM
My goal is to make a RC Quadrotor.Up, down, left, right, forward, backward and hover. Wireless data transfer would be through XBee and the controlling will be done through PIC micro controller.
