RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Thrust (https://www.rcuniverse.com/forum/questions-answers-154/1102750-thrust.html)
68zbuff 08-30-2003 06:34 PM
Thrust
Could anyone tell me how to figure thrust? I have an O.S. 46fx spinning an apc 12.25x3.75 at 12,800 rpm. Is there a formula to get x#pounds of thrust?
Rj
Papa Tango 08-31-2003 12:01 AM
Thrust
I would think you would also have to factor in other variables such as:
Temperature
Relative Humidity
Altitude
You could look at some Aerodynamics sites, but I doubt you will find the Formula you are seeking. After all, even though you supply such data as prop diameter and pitch, that doesn't take into account the airfoil that the manufacturer employs in shaping that particular propeller. What about the propeller tip design? Some would increase drag in an effort to reduce noise, while another would sacrifice this for increased thrust.
I'm sure you will agree there is no need for further examples.
Good Luck to you!!
68zbuff 09-01-2003 01:06 AM
Thrust
I guess that would be a lot of trouble. Does anyone run this setup and know what kind of thrust they are getting?
RJ
rogwabbit 09-01-2003 01:12 AM
Thrust
if your getting that i'm impressed.. thats about 10lbs thrust from what i can tell
68zbuff 09-01-2003 01:16 AM
Thrust
I run Omega 15%, and also have a Tower muffler on it. I have the engine on a profile hots and it truly has a rocketing unlimited performance.
Rj
viper1 09-01-2003 02:22 AM
Thrust
Rj,
There is a little software thrust calculator called; "ThrustHP"
simple to use, see 'download' on my web page
Regards,
G.J.
68zbuff 09-01-2003 03:31 AM
Thrust
Viper1,
Thanks for the information, I downloaded the program, it was exactly what I was looking for.
Isn't this a great web site? Thanks to all the information it makes our hobby more enjoyable.
Rj
ekrcflyer 09-09-2003 10:33 AM
RE: Thrust
To viper1’s post:
Very good piece of software and an awesome website. Thanks!
