DLE 20 - tuning
I've got the DLE 20 in my Pulse 125 turning a 16 x 8 Xoar prop. I've got some numbers but I think they're a little low, so I'd appreciate a second (third, fourth etc) opinion:
RPM @ WOT: ~7500 Static thrust: 11.75 lbs Here's a clip of the throttle response. The first time I started the plane it stuttered when the throttle was opened and sometimes quit at full throttle. Per the DLE manual I opened up the High adjustment screw on the carb about 1/8 turn and it improved. If I open it too much further it starts to miss, which I assume means too rich. So, the questions. 1. The manual specifies 2.5 HP @ 9000 RPM. I am running a recommended prop size. Should I expect 9000 RPM? 2. I've seen other reports of the static thrust at 13-14 lbs... is 11.75 low enough to cause concern? 3. I've backed off the idle to about 2000 RPM, but it's pretty shaky at that setting. Is this a good idle speed? Cheers! |
RE: DLE 20 - tuning
If you go into the gas engine forum there are pages and pages on the DLE 20. I have tuned a couple of them for friends at the field but never bothered doing any prop testing or static thrust testing with one. The one thing I have learned with all the DLE engines it toss the spark plug that came with the engine and install an NGK CM-6. That no name thing from China is about useless and creats a lot of problems.;)
