OPTO KILL SWITCH ROUTING PROBLEM
Can someone send me a picture or a diagram of a rcexl opto
kill switch routed through a on/off switch, that is then routed to the receiver. My problem is, that when I route the opto to the on/off switch and try and read the battery output I get no reading/power. When I plug the battery directly to the switch and test it, I get a good reading. My routing must be faulty somewhere but I can't seem to find my mistake. Any help is appreciated. Thanks, Aframe2 |
RE: OPTO KILL SWITCH ROUTING PROBLEM
Battery, Switch, Optical Kill, Ignition. using the red two wire leads.
The 3 wire male goes to the reciever aux channel. |
