RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   New Pitts python radio setup help needed (https://www.rcuniverse.com/forum/questions-answers-154/11266306-new-pitts-python-radio-setup-help-needed.html)
Shiftyeddie 10-17-2012 01:36 PM
I have stepped up my game to my first 50cc plane.
I have a Aeroworks Pitts Python which I will be using a total
of 8 servos
4 aileron
2 elevator
1 rudder
1 Throttle
I have (for now) a DX7s Radio.
I was told I could set this plane up with this radio without
the need of a matchbox. (Not adding smoke system or Choke servo)
Can anyone help me out with the configuration?
I was thinking 1 Y connector per wing, one going to
Aileron and the other going to Aux..
Any help would be greatly appreciated!!!
<br type="_moz" />
jetmech05 10-17-2012 04:52 PM
RE: New Pitts python radio setup help needed
I have this airplane. I Yed my 2 upper servos...keeping the Y in the fusleage, Yed the 2 lower servos then used seperate channels in the radio for upper and lower....Trust me when I say I found my airplane to be exteremly sensitive in ailerons....and extermely nose heavy....get with an expereinced bipe flyer to do your CG use Expo and reduce the throws on ailerons a bit....With that said I have flown mine now for over 3 years
Gray Beard 10-17-2012 06:42 PM
I'm using a 9 ch. radio and had the same set up, I went with a JR match Box on the ailerons and made my life easier.
Shiftyeddie 10-18-2012 08:45 AM
Does one Matchbox not control all 4 aileron servos?
I see on the forums that people put a matchbox on each side.<br type="_moz" />
jetmech05 10-18-2012 04:50 PM
A match box usually is used for multiple servos on a single control surface...like 2 or 3 servos on a single aileron. It allow you to set the servos so they don't fight each other at deflection. In this case I can see where the match box inside the fuse then hook each aileron servo to it would be easy
tacx 10-19-2012 06:32 AM
Can't you just parrallel all the aileron servos together and plug into the aileron channel? This should give you the same results as a single wing with both servos Y ed and plugged into the aileron channel. Although this setup won't allow you to program in any differential or seperate adjustment of the servos.
jetmech05 10-19-2012 07:20 AM
Hi tacx...yes you can do that...but how would you go about paralleling the servos? A bunch of Y's? I suppose you couls make an extension.... if you treat each wing seperate.....and loose a connection you still have ailerons on each wing
Mustangman40 10-20-2012 07:56 AM
I went with a Power Expander Pro from Smart-Fly on my 50cc Pitts Python, the $149.00 price tag was way worth it... I was able to plug in all 4 ail. without any "Y's" as well as my Elv and didn't have to do any mixing, it made set up as easy as a 4ch trainer..Italso is set up for two batteries and regulates the power to the RX to 5 volts but allows full power to the servos and I only need the one pin style failsafe switch..http://www.rcuniverse.com/forum/js/f...wink_smile.gif
Jimbo
Shiftyeddie 10-21-2012 09:27 AM
Sounds good mustang :)
I think thats what I will do.
