46 SF needle assemby needed
I need a needle valve assembly for a 46 SF engine. It is a discontinued engine and the carb has 4D marked in it. Can some one tell what will fit and where to get it. Thanks
RE: 46 SF needle assemby needed
I have the 46 sf engine manual in pdf format. i can send it to you if you need it for reference.
Grinder. |
OK, the OS part number for the complete needle assembly is OSMG7255. You can get one from Tower Hobby for 15.49 plus shipping. Just go to Towers' website and search for the above part number. That will take you to the part and you can order it. Or you should be able to get one through your local hobby shop.
Grinder, I have just located, and downloaded that PDF from the web. I do appreciate your help .
Thanks |
Ghendrix, You are right on the needle valve part #. I was able to get one at a local hooby store for 16 and change. Thanks for the help
