EPP Foam & CA Glue
I was given an EPP electric profile kit by my son. Can you use regular CA glue on this type of foam or must you use the foam-safe kind? The instruction do not discern.
RE: EPP Foam & CA Glue
yes you can use regular CA on EPP. But I don't recommend it. The joint is brittle and not flexible. Welders or UHU glue works much better. There is also a foam safe glue some of the electric suppliers are starting to sell that is getting good reviews.
| All times are GMT -8. The time now is 11:51 PM. |
