Hitec HS7245MH servo issue
Has anyone had or heard of issues regarding:confused: the Hitec HS7245MH servos?
I have two with the same problem. They only travel one direction. Gears appear fine??? |
Have you tired those servos in a different location? I mean just plug them in a different channel and see.
Or use a different radio |
Originally Posted by jetmech05
(Post 11737017)
Or use a different radio To go along with the above, have you tried other, known good, servos in the "bad" servo locations ? |
If memory serves, that servo is programmable. You might want to hook it to a programmer and reset it to defaults, especially if you bought them used.
