RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   A 2.4ghz question (https://www.rcuniverse.com/forum/questions-answers-154/11617891-2-4ghz-question.html)
Steve Collins 06-01-2015 03:26 PM
A 2.4ghz question
I have a lot of buffered servo extensions left over from the 72mhz days. Can these be used with 2.4ghz radio systems without issues?
Please do not speculate because I can do that myself. If you have direct knowledge or experience related to this question, you are the one I want to hear from.
Steve Collins 06-03-2015 06:59 PM
Amazing! Nobody knows!!
GREG DOE 06-03-2015 08:15 PM
Steve, I would check with one of the radio importers. I personally don't know the answer to your question. If the extensions were mine,
I would just cut buffer devices out, and splice the extensions back together.Good luck.
Steve Percifield 06-03-2015 10:07 PM
I agree. I doubt that the frequency matters. But a quick check with the manufacture would give you a safe answer. BTW, I was told a long time ago that tying a knot in long extensions does the same as a ferrite bead or ring and I have always done that. And as a habit, still do that on all my 2.4 stuff and have never had an issue. But now you make me think about doing it??
jetmech05 06-04-2015 04:10 AM
The freq that the system works doesn't matter your servo has three wires. Power, return, and signal. You can use any servo, you can use any extension
ALbert.S 06-04-2015 05:13 AM
The Spektrum manual says DO NOT USE THEM
Copyright 2018 MH Sub I, LLC dba Internet Brands. All rights reserved. Use of this site indicates your consent to the Terms of Use.
