Good Quality Razor Saw
Who makes a good quality razor saw that cuts on the pull stroke and can cut brass, aluminum and mild steel (e.g. small bolts)? I have an old Zona saw that I've used for 30 years and have finally worn it out. I bought a new Zona with multiple blades and they are certainly not the same quality as the old one! :mad: I need one with about a 5" long blade, that will cut over 1/2" deep (for clearance when cutting thin sheet stock), and something like 42 tpi. Blade thickness of 10 thou or so.
I can't tell you about it first hand.. But I know I recently read of someone preferring the saw he had bought at Harbor freight to his Zona.. I was surprised by that and I recalled it when I read your post.
Hay Fanatic
I don't have there web site info but look at micro-mark they have a lot of tools for the train guys Hope this helps Cheers Bob T |
Originally Posted by foodstick
(Post 12055081)
Originally Posted by tunakuts3d
(Post 12055773)
Thanks for the link though. There are some interesting tools there. |
