need carburetor for os .61 sf
I got a brand new os .61 sf but the carburetor is broke I need one can anyone help? |
I will give a reply, no I can't help wish I could. But at least you will know that your post was read
Bob |
PM sent
How is it broken?
You might try a post on the glow engines forum on RCU here http://www.rcuniverse.com/forum/glow-engines-114/
If that fails these guys keep a lot of spares and are also likely to know if there is an alternative carb that fits. http://www.justengines.co.uk/acatalo...ke_Spares.html It would be useful to measure the throat diameter for the carb, the outside diameter. |
the fuel line nipple cracked out of the carb and chipped the carb in shipping the guy didnt pack it well
Sounds like a non-stress area. Could it be fixed with JB Weld, at least until you can locate a replacement?
Originally Posted by rcworld2000
(Post 12083591)
Hi!
I assume you have got a carb with a 13mm neck?! I have both 8mm.9mm and 10mm MVVS carbs that fits your OS. |
