prop for saito 1.20
ok guys i have a saito 1.20 in a SEAGUL lazer 200
i have a 16x8 prop on it but it seems like i can get some more power out of this engine. what size prop do you guys suggest |
run a 15/8 u'll see a big difference in performance
Originally Posted by abacro
(Post 12105862)
the 15/10 is the same as the 16/8 ur running now! just a smaller diameter to allow for ground clearance! General guide to 120 prop sizes I've found is 14/10 or 14/12,15/6 to 15/12 and 16/4 to 16/10 but that depends on your application.Contrary to what EVERYONE will tell you,you want the 4 strokes to turn between 9500 and 10,200 rpms on the ground.They all build max Hp in the 10500 to 11000 rpm ranges.with the 15/8 prop u shouls see anywhere from 9700 to 10,000 rpm on the ground.
good luck Art |
Hi!
15x10 is too big! 16x6 or 15x8! |
(Post 12105862)
