RCU Forums
-   Questions and Answers (https://www.rcuniverse.com/forum/questions-answers-154/)
-   -   Hot wire power (https://www.rcuniverse.com/forum/questions-answers-154/11623659-hot-wire-power.html)
RAPPTOR 11-15-2015 06:34 AM
Hot wire power
Any simple setups?
Propworn 11-15-2015 06:47 AM
Lots of options at Aircraft Spruce http://www.aircraftspruce.com/catalo...clickkey=79333
Even wire supplies as well
RAPPTOR 11-15-2015 07:49 AM
Perfect thanks
j.duncker 11-15-2015 04:48 PM
I used a very simple non smart 12 volt 5 amp battery charger feeding into an old 12 volt battery. This drove a 40 inch bow with no trouble.
I established the length by varying the wire length and seeing what cut well.
049flyer 11-16-2015 09:36 AM
I use an Astroflight 110d charger so I can precisely control the heat. You can buy them for peanuts at swap meets and online auctions. They have a test/diagnostic mode which turns them into a current adjustable power supply. Perfect for hot wire cutting.
